| spare engine https://slantsix.org/forum/viewtopic.php?t=59563 |
| Author: | 63dartconv [ Sat Apr 30, 2016 5:50 pm ] |
| Post subject: | spare engine |
I have a spare stock engine, since I have had the problems with the engine I'm building etc, can I bolt my head, which is .100 shaved, onto the stock engine? and also can I put my 4 barrel and headers on it? I don't have a one or two barrel. I am putting this in my dart for the mean time til my other engine is done. |
| Author: | sandy in BC [ Sat Apr 30, 2016 6:08 pm ] |
the only issue other than driveabilty <ping> might be pushrods |
| Author: | 63dartconv [ Sat Apr 30, 2016 6:12 pm ] |
What issue with drivability? I can get shorter PR, but I don't believe I need those for .100 off the head. I think there is enough adjustment there. Can anyone verify this? |
| Author: | slantzilla [ Sat Apr 30, 2016 6:47 pm ] |
Depends on the cam. If it is a reduced base circle your pushrods will probably be OK. If it is a stock cam they may be too long. Sooooo, the only correct answer is you will have to check when you install the head. |
| Author: | 63dartconv [ Sat Apr 30, 2016 6:50 pm ] |
As far as installing a "rebuilt" head on a used engine, is that ok? |
| Author: | Joshie225 [ Sat Apr 30, 2016 7:56 pm ] |
So long as the bottom end isn't on its last legs it will be fine. |
| Author: | 63dartconv [ Sat Apr 30, 2016 8:46 pm ] |
Will it be fine with the four barrel since it really isn't a "hopped up" engine? |
| Author: | Joshie225 [ Sat Apr 30, 2016 8:54 pm ] |
Maybe. Depends on how good you are at tuning. I put a ported big valve head on my stock '67 engine with a Holley 390 on an Offy intake. Worked fine. |
| Author: | 63dartconv [ Sat Apr 30, 2016 8:55 pm ] |
Ok. I appreciate the help |
