It is currently Thu Jun 25, 2026 5:58 am
 Post subject: Cam degree
PostPosted: Tue May 03, 2016 1:12 pm
Hi guys, i recently got my reground cam back, its #791 from ocg.
I was wonder if i should advance it at all or install it as it says. I have a 225 around 9.2-9.5 static comp, big valve, port head, offy intake, long tube mp header, 2500 stall converter, and 3.23 gears. The contverter and gears are more than likeley going to be changed. Its a street/strip build. More street than strip.
Thanks matt
 Post subject: Yep...
PostPosted: Tue May 03, 2016 5:54 pm
791 with only 9.2-"ish" compression...Yeah...getting the intake center lined around 102 would be worthwhile....
