| T-5 Conversion yeh and neh? https://slantsix.org/forum/viewtopic.php?t=59583 |
| Author: | Harper [ Mon May 02, 2016 2:18 pm ] |
| Post subject: | T-5 Conversion yeh and neh? |
I am very interested in the T-5 swap in place of my stock 3 speed manual with (sloppy shakespear after market floor shifter) is there a reasonable bell housing for this swap? what else would be needed? I can see this being a great thing, an overdrive in behind a slant 6 would make a heck of a fun driver!!! |
| Author: | DusterIdiot [ Mon May 02, 2016 6:17 pm ] |
| Post subject: | Yeh. |
If you use the search function, there are a few good posts on the subject, you will need to have your bellhousing or a spare altered to take the transmission. You will also want to look at the various versions and determine which will work best for your setup. I always figured with a heavier car like a B or E-body that a set of 3.91 or 4.11's and the "Cobra/SVT" box would be about perfect to get the larger car off the line and be respectable in OD for mileage. |
