It is currently Mon Jun 01, 2026 9:35 pm
PostPosted: Fri May 20, 2016 5:16 am
Car Model: 1938 Plymouth 4 dr. sedan
Does anybody have GOOD/ACCURATE dimensions for the mounting holes to the block on the /6 water pump, especially the holes toward the top of the pump. I am in process to make my own A/C compressor brackets, have measured off the holes using a new water pump gasket, but was wondering if anyone has more accurate dimensions. Thanks
Street rod an old car and then drive/use it. I'm a NSRA safety inspector if anyone ever wants that done to their car.
PostPosted: Fri May 20, 2016 5:22 pm
I just ran those dim on my DRO mill a couple of weeks ago, I'll see if I have them Sun Pm when I return if no one else comes up with them.
