| bent pushrod repair? https://slantsix.org/forum/viewtopic.php?t=59611 |
| Author: | pishta [ Sat May 07, 2016 3:31 pm ] |
| Post subject: | bent pushrod repair? |
I blew it and torqued down my valvetrain with 1 pushrod not seated in the lifter, bent it pretty good. I was able to pound it straight with just a ripple of a tweak. Can I run it or is that an absolute no-no? Does anyone got a spare mechanical pushrod they want to donate? |
| Author: | 1930 [ Sat May 07, 2016 3:34 pm ] |
I have plenty of spare hyd. if that in any way helps |
| Author: | SlantSixDan [ Sat May 07, 2016 3:50 pm ] |
Put in a dead-straight pushrod. They're cheap and it's easy and it'll avoid problems down the line. |
| Author: | Joshie225 [ Sat May 07, 2016 3:52 pm ] |
Don't run it unless you want to tear it apart again in short order. |
| Author: | pishta [ Sat May 07, 2016 6:36 pm ] |
Noted. Does anyone have a solid lifter ball/cup pushrod they can spare? Ill compensate...Thanks. So.Cal. |
| Author: | slantzilla [ Sat May 07, 2016 7:38 pm ] |
If it's a stck cam and valvesprings running it will probably not hurt a thing. Bill's stock motor in his Dart has had 2 in it for years that I straightened with a hammer just to get him going. |
