It is currently Mon Jun 22, 2026 3:47 am
 Post subject: Question
PostPosted: Sat May 07, 2016 2:06 pm
I removed the crank bolt so I could remove the HB and some oil came out. Also when I removed the timing cover, water came out of one of the bolt holes. Is this normal?
PostPosted: Sat May 07, 2016 3:55 pm
Oil tends to creep behind the damper and into the bolt hole. No worries, but you can put a little non-hardening sealer in the damper bore if you like.
Yes, an upper timing cover bolt goes into the water jacket. No worries. Just put some sealer on the bolt when it goes back in.
PostPosted: Sat May 07, 2016 6:36 pm
As far as the oil question, I have only ran the engine for 5 minutes or so. Is that still ok?
PostPosted: Sat May 07, 2016 10:05 pm
I don't understand the question.
PostPosted: Sun May 08, 2016 7:54 am
You said the oil tends to creep behind the HB bolt. Is this normal with only 5 minutes of run time after rebuild?
PostPosted: Sun May 08, 2016 8:43 am
No. Are you sure the damper was tight against the crank sprocket?
PostPosted: Sun May 08, 2016 8:54 am
Are there specs on how close to the timing cover it should be?
