1970 Dart A-833 Shifter Location
https://slantsix.org/forum/viewtopic.php?t=59631
Author:  casedawg [ Wed May 11, 2016 1:28 pm ]
Post subject:  1970 Dart A-833 Shifter Location
Does anyone have the measurement for where the shifter is located in the car in relation to the firewall or bellhousing face? How far away is it?
Thanks,
Casey
Author:  Nicademas [ Wed May 11, 2016 5:30 pm ]
Its kinda pricey but this might help you.
http://www.classicindustries.com/produc ... m1227.html
Author:  casedawg [ Thu May 12, 2016 2:23 pm ]
I'm looking for the info for a transmission swap other than a stock 4 speed. I'm guessing that piece just nests into the contours of the floor for location rather than placing it a certain distance from the firewall.
Any 4 speed A body owners out there who could take a quick measurement?
Author:  62 alum [ Mon May 30, 2016 11:15 am ]
I measured 19 inches from the bell housing/transmission interface to the center locating bolt for the hurst shifter. This is on a a833 od a/f trans.
Hope this is of some help.
Author:  casedawg [ Tue May 31, 2016 5:35 pm ]
Thanks! So that is basically to the base of the shift lever where it comes through the floor?
Author:  62 alum [ Wed Jun 01, 2016 3:06 pm ]
Yes, When the transmission is in neutral the shift lever is in the vertical position coming thru the floor. The bolt I spoke of is directly below the lever.
Also measured a stock 3 speed with floor shift, same thing 19 "
Author:  casedawg [ Wed Jun 01, 2016 5:49 pm ]
Thanks. That helps me confirm what I need for my 6 speed conversion.
