| 66 Barracuda brake size https://slantsix.org/forum/viewtopic.php?t=59653 |
| Author: | Charrlie_S [ Tue May 17, 2016 10:00 am ] |
| Post subject: | 66 Barracuda brake size |
What size rear brakes were on a 66 Barracuda with a 273 V-8? Car has 10 fronts did the 7 1/4 rear have 9's or 10's? Thanks |
| Author: | SlantSixDan [ Tue May 17, 2016 10:48 am ] |
Cars with 7-1/4" rear axles came with 9" or 10" brakes, front and rear, depending on the whole-vehicle specifications and/or what was ordered at new-car purchase time. Always the same diameter front and rear, never 10" fronts with 9" rears or vice versa. The V8 cars came with 10" brakes as standard equipment. |
| Author: | Charrlie_S [ Tue May 17, 2016 6:06 pm ] |
OK, Thanks. Putting my 66 Cuda back to stock, and wasn't sure which was the correct 7 1/4 rear. |
| Author: | SlantSixDan [ Tue May 17, 2016 9:01 pm ] |
The rear axle assembly isn't different for 9" vs. 10" brakes; it's just a matter of what parts are bolted onto the ends of the axle tubes. |
| Author: | Charrlie_S [ Wed May 18, 2016 4:06 am ] |
Quote: The rear axle assembly isn't different for 9" vs. 10" brakes; it's just a matter of what parts are bolted onto the ends of the axle tubes.
I was/am aware of that. I Have a couple of different rears, of unknown yearsboth 9 and 10 inch brakes, plus later LBP 10 brake pieces. just wanted to put in a rear with the correct configuration. Thanks |
