| No reverse in auto tranny https://slantsix.org/forum/viewtopic.php?t=5966 |
| Author: | mszauner [ Tue Jun 10, 2003 8:29 am ] |
| Post subject: | No reverse in auto tranny |
My 1973 Duster automatic tranny has no reverse gear functioning. I am told that it will require a rebuild to correct. Does that sound right or are there further checks or adjustments I can make. If adjustments will only last me a couple months, I would rather just rebuild now and get it over with. Thanks for any input. Mike |
| Author: | Doc [ Tue Jun 10, 2003 9:23 am ] |
| Post subject: | Re: No reverse in auto tranny |
Quote: My 1973 Duster automatic tranny has no reverse gear functioning. I am told that it will require a rebuild to correct. Does that sound right or are there further checks or adjustments I can make. If adjustments will only last me a couple months, I would rather just rebuild now and get it over with. Thanks for any input.
You need to drop the pan and take a look, the fix could be as easy as tighting the band adjuster, sometimes the locknut backs-off and the lever loosens-up to the point where the activating strut falls-out.Mike The other cause is blow servo seals, those can also be replaced with-out removing the trans. Pressure test the servo. The "killer" is a broken reverse band, this happens now and then. The trans needs to be torn-down to fix that problem. DD |
| Author: | bud L. [ Wed Jun 11, 2003 10:24 pm ] |
| Post subject: | more |
if the idle is excessively fast when reverse is engaged, it can often result in a broken band. |
