| NHRA class question https://slantsix.org/forum/viewtopic.php?t=59734 |
| Author: | JohnnyDees [ Sun Jun 05, 2016 1:07 pm ] |
| Post subject: | NHRA class question |
I read an old post about Mike Jeffries setting the V/SA national record. I have seen the Buzzin' car. But if V/SA is 22 lbs per cubic inch and assuming the engine is a 225 does that mean the vehicle weight is 4950? somethin' aint right in my thinkin'.....Maybe its not a slant? |
| Author: | Charrlie_S [ Sun Jun 05, 2016 2:46 pm ] |
| Post subject: | Re: NHRA class question |
Quote: I read an old post about Mike Jeffries setting the V/SA national record. I have seen the Buzzin' car. But if V/SA is 22 lbs per cubic inch and assuming the engine is a 225 does that mean the vehicle weight is 4950? somethin' aint right in my thinkin'.....Maybe its not a slant?
That is 22 lbs per hp, not cubes. Not sure what the NHRA "factored" HP, is.
| Author: | JohnnyDees [ Sun Jun 05, 2016 3:40 pm ] |
Thanks Charlie |
| Author: | JohnnyDees [ Sun Jun 05, 2016 3:43 pm ] |
I used to know that once... |
| Author: | slantzilla [ Sun Jun 05, 2016 7:54 pm ] |
Not sure what his HP is right now. He got some taken away a few years ago, but has been "awarded" some back a couple times since then. Last I knew I think the Dippy weighed about 3350. |
| Author: | Dart270 [ Mon Jun 06, 2016 4:11 am ] |
To clarify, Mike is not racing the Buzzin Half Duzzin car (68 Valiant). He runs a Diplomat (1980?) in V/SA, as Zilla mentioned. Best, Lou |
| Author: | Charrlie_S [ Mon Jun 06, 2016 5:19 am ] |
Just an example. When I raced my 65 Valiant in stock eliminator, back in the "70"s, it ran Z/SA, at 25 Lbs/HP. Had a 170 engine rated at 101 HP (was not refactored). Car had to weigh 2525 lbs, and hit the scales at 2530 lbs. PS: It could run mid 16's with a best of 16.2 on a 17.36 index. |
| Author: | JohnnyDees [ Mon Jun 06, 2016 7:33 am ] |
Thanks for the replies.... some day I might try to enter an event just for the experience |
| Author: | slantzilla [ Mon Jun 06, 2016 8:27 am ] |
The Stocker is "Buzzin' Half Duzzin' Too". |
| Author: | Charrlie_S [ Mon Jun 06, 2016 6:13 pm ] |
Quote: Thanks for the replies.... some day I might try to enter an event just for the experience
That can be an expensive endevor. Stock is far from stock.
| Author: | slantzilla [ Mon Jun 06, 2016 6:27 pm ] |
As long as you're in a lower class and not trying to set records, V can be pretty reasonable, especially if you stumble on a car someone else gave up on. |
| Author: | JohnnyDees [ Mon Jun 06, 2016 7:42 pm ] |
Not trying to set records... |
| Author: | slantzilla [ Tue Jun 07, 2016 12:13 am ] |
If you really want a V car Mike might be tempted into selling you his. |
