| 450-500hp? https://slantsix.org/forum/viewtopic.php?t=59744 |
| Author: | h0ndansr [ Tue Jun 07, 2016 5:13 am ] |
| Post subject: | 450-500hp? |
Hi. I'm gonna start to build a new engine for my -80 Aspen and would like to get 450-500hp. Any help I can get would be nice. I will use a roots supercharger e85. Thanks. |
| Author: | Joshie225 [ Tue Jun 07, 2016 8:10 am ] |
Welcome! At the boost required to make 450hp you're better off with a turbocharger or a screw compressor than a Roots blower. While there are some very fast carbureted turbo cars many (most?) use alcohol injection as a supplemental fuel and detonation suppressant. EFI I feel is a good choice as it gives a lot more control over fuel and ignition which helps keep pistons and head gaskets healthy. I highly recommend spending some time in the boost and nitrous section and reading about head gaskets, o-rings and head studs. |
| Author: | wjajr [ Tue Jun 07, 2016 9:16 am ] |
You may want to give serious consideration to beefing up brakes and suspension with that kind of power. |
| Author: | Badvert65 [ Tue Jun 07, 2016 9:25 am ] |
Being conservative? Only 450-500 HP? |
| Author: | h0ndansr [ Tue Jun 07, 2016 11:20 am ] |
Quote: Being conservative? To start with Only 450-500 HP? |
| Author: | h0ndansr [ Tue Jun 07, 2016 11:21 am ] |
Quote: You may want to give serious consideration to beefing up brakes and suspension with that kind of power. Yes I will upgrade because I think the 100hp is almost to much for the brakes and suspension.
| Author: | h0ndansr [ Wed Jun 08, 2016 10:44 am ] |
Does anybody know wich block is stronger or if they are equally strong. the one with 3 or 5 freezeplugs? |
| Author: | slantzilla [ Wed Jun 08, 2016 10:54 am ] |
In all honesty, there really isn't much difference between blocks. What blower are you going to use? Member terry littlejohn is using a 6-71 and can probably be a lot of help to you. |
| Author: | h0ndansr [ Wed Jun 08, 2016 12:00 pm ] |
Quote: In all honesty, there really isn't much difference between blocks. I was actually thinking of using a 6-71 What blower are you going to use? Member terry littlejohn is using a 6-71 and can probably be a lot of help to you. |
| Author: | '67 Dart 270 [ Wed Jun 08, 2016 9:04 pm ] |
| Post subject: | ...curious |
...is this a strip car or a street car? 450+ hp from a slant is awesome. If a strip car, people will be impressed (as they should), but if a street car, people will be in awe, jaw-dropping power from an I6....love it. |
| Author: | slantzilla [ Wed Jun 08, 2016 11:47 pm ] |
Terry might be using a 4-71. Seymour had a buddy with a 4-71 back in the late '90s. IIRC, it made well over 400 back then. |
| Author: | h0ndansr [ Thu Jun 09, 2016 2:24 am ] |
| Post subject: | Re: ...curious |
Quote: ...is this a strip car or a street car? 450+ hp from a slant is awesome. If a strip car, people will be impressed (as they should), but if a street car, people will be in awe, jaw-dropping power from an I6....love it. It will be a street car |
| Author: | Dart270 [ Thu Jun 09, 2016 7:57 am ] |
The Slant 6 seems to respond very well to boost. We hope your project goes very well! There are a few other cars in Scandinavia (Finland included) on this site. Lou |
| Author: | wjajr [ Thu Jun 09, 2016 1:05 pm ] |
Here is an interesting site that may help. |
