| New Manifold Source https://slantsix.org/forum/viewtopic.php?t=59768 |
| Author: | Augie Dog [ Mon Jun 13, 2016 7:46 am ] |
| Post subject: | New Manifold Source |
I was looking at some of the vendors on here and could not see any that carry stock manifold for our Slant's. Who do ya'all like as a reliable source? I saw on Rock Auto, Ebay, and another source but was concerned they are cast in China. Is the Dorman brand still made here in the US? Sorry for so many questions but I figured since I'm into this fuel injection upgrade I may as well slap a new exhaust manifold on this engine. Thanks!! |
| Author: | Joshie225 [ Mon Jun 13, 2016 8:10 am ] |
http://slantsix.org/forum/viewtopic.php ... man#442982 |
| Author: | SlantSixDan [ Mon Jun 13, 2016 9:46 am ] |
| Post subject: | Re: New Manifold Source |
Quote: concerned they are cast in China.
Yes, they are.Quote: Is the Dorman brand still made here in the US?
It never was. However, it is the best quality option presently available. As you can see, the Dorman item is more expensive than the "same" manifold—see Joshie225's link—from other companies. The reason is simple, you (don't) get what you (don't) pay for.
| Author: | Augie Dog [ Mon Jun 13, 2016 11:23 am ] |
Thanks for all the info! I'm checking everything out especially the Remline gaskets. I believe I'm going to go with the Offenhauser manifold if I can get Dan the guy from N. Georgia to get back with me. Let me ask one more question because not asking questions is what took me down the wrong path. It is my understanding the Offenhauser manifold will mate up to the stock slant exhaust manifold is that correct. If I put a block off plate over the stove portion of the manifold will I still be able to mate the two manifolds up? Thanks everyone!! |
| Author: | SlantSixDan [ Mon Jun 13, 2016 11:31 am ] |
Quote: It is my understanding the Offenhauser manifold will mate up to the stock slant exhaust manifold is that correct
Yes.Quote: If I put a block off plate over the stove portion of the manifold will I still be able to mate the two manifolds up?
No, and that would be a bad idea even if you could.
| Author: | Augie Dog [ Mon Jun 13, 2016 11:53 am ] |
Quote: Quote: It is my understanding the Offenhauser manifold will mate up to the stock slant exhaust manifold is that correct
No, and that would be a bad idea even if you could. |
| Author: | SlantSixDan [ Mon Jun 13, 2016 12:42 pm ] |
Quote: I will be using a FI throttle body from a company called FiTech and not a carburetor.
Throttle-body injection like that is still a wet-manifold system, and still wants manifold heat for all the same reasons a carbureted system wants it. Only with port fuel injection would you want to look at eliminating intake manifold heat. This 1935 Jam Handy cartoon, "Down the Gasoline Trail", would be a real trip to watch even if it didn't contain a sequence specifically answering this question about the manifold heat (at 5:37).
| Author: | Augie Dog [ Wed Jun 15, 2016 3:42 am ] |
Quote: Quote: I will be using a FI throttle body from a company called FiTech and not a carburetor.
Throttle-body injection like that is still a wet-manifold system, and still wants manifold heat for all the same reasons a carbureted system wants it. Only with port fuel injection would you want to look at eliminating intake manifold heat. This 1935 Jam Handy cartoon, "Down the Gasoline Trail", would be a real trip to watch even if it didn't contain a sequence specifically answering this question about the manifold heat (at 5:37).Thanks Again |
| Author: | JBracey [ Wed Jun 15, 2016 9:25 am ] |
| Post subject: | Remflex |
You're probably thinking Remflex and not Remline Remflex gaskets can be purchased from their site here: http://catalog.remflex.com/category_s/87.htm Or on amazon here: https://www.amazon.com/Remflex-6008-Exh ... B00C5T8YMA |
| Author: | Augie Dog [ Thu Jun 16, 2016 2:53 pm ] |
| Post subject: | Re: Remflex |
Quote: You're probably thinking Remflex and not Remline
Thank you for correcting me JBracey. I would have been searching on Remline trying to figure out why they didn't have gaskets! Lol Remflex gaskets can be purchased from their site here: http://catalog.remflex.com/category_s/87.htm Or on amazon here: https://www.amazon.com/Remflex-6008-Exh ... B00C5T8YMA |
