| turbo https://slantsix.org/forum/viewtopic.php?t=5979 |
| Author: | turbo me [ Wed Jun 11, 2003 5:50 pm ] |
| Post subject: | turbo |
Is there any info that someone can give me on turboing my slant. i will need all that will need to be done.my buddy has one that he will give me just do not have a clue how to thanks for any help |
| Author: | Dart270 [ Wed Jun 11, 2003 11:03 pm ] |
A good place to start is a book by Corky Bell called "Maximum Boost." www.wagnermotorsports.com is another good place to go for info. You should give Andrew Wagner a call there if you are serious. He can give good advice and fabricate parts for you. Lou |
| Author: | Matt Cramer [ Thu Jun 12, 2003 5:53 pm ] |
| Post subject: | Turbos |
<i>Maximum Boost</i> is a good book, but I sometimes think Corky Bell mixes facts and opinions a bit freely and doesn't always say which is which. It's still a great book for building a turbo car, particularly a EFI one. However, Hugh MacInnes's <i>Turbochargers</i> has a lot more to say about carbs and turbos. However, I'd recommend both - it's hard to research something too well before starting! BTW, what turbo is it your buddy has? Not all of them work well on slants... |
| Author: | turbo me [ Thu Jun 12, 2003 6:47 pm ] |
it came off buick gn t 100 i think |
| Author: | Matt Cramer [ Fri Jun 13, 2003 7:26 pm ] |
| Post subject: | GN turbo |
Yeah, that's perfect. The Buick V6 is almost exactly the same size as a slant six. It's just that there are used turbos floating around off everything from Chevy Sprints to big rigs, and I've seen some incredibly creative mismatching. My favorite was a Buick V6 turbo on a lawnmower engine - it wouldn't spool unless they fed it with compressed air through the exhaust, and then it would hit the surge limit.... |
| Author: | rad74225 [ Sat Jun 14, 2003 9:22 am ] |
This is interesting |
| Author: | Al T [ Sat Jun 14, 2003 11:02 am ] |
| Post subject: | Answer to your question |
Rad to answer your question about stock and turbos, do a search on Tom Drake. Happy reading! |
| Author: | Matt Cramer [ Sun Jun 15, 2003 6:04 pm ] |
| Post subject: | Depends on what turbo |
Different turbos work best at different RPM's. For example, a stock slant six spinning at around 3,000 RPM with a TE04 off a K-car turbo at around 8 psi of boost would be right smack dab in the peak efficiency of the turbo. A Buick turbo might be happier another 1,000 RPM or so higher, although I can't verify that without a compressor map. But the Buick Turbo V6 is no rev-monster either. So I'd expect it to be a reasonable match for a slant six. |
