| 1920 rebuild https://slantsix.org/forum/viewtopic.php?t=59816 |
| Author: | davidrad [ Sat Jun 25, 2016 11:46 pm ] |
| Post subject: | 1920 rebuild |
hi guys. I rebuilt the carb but have the dreaded peice left over. It looks to be the idle compensator gasket. It's a small yellow oring. any idea where this goes? It's not in the manual. Thanks |
| Author: | SlantSixDan [ Sun Jun 26, 2016 9:55 am ] |
It goes behind the bimetallic hot idle compensator, which in turn is behind the small rectangular sheetmetal cover on the driver's side of the carb. |
| Author: | davidrad [ Sun Jun 26, 2016 12:43 pm ] |
| Post subject: | extra oring holley 1920 r6260 |
My type doesn't have those peices.The casting has those ports covered as well as the screw holes. |
| Author: | SlantSixDan [ Sun Jun 26, 2016 1:33 pm ] |
Then you don't need that O-ring. |
| Author: | davidrad [ Sun Jun 26, 2016 2:26 pm ] |
I thought it came off the the carb and not from the kit. I must have been wrong. Thanks for putting my mind at ease. Now, to get rid of the vacuum leak at the trottle rod. |
