| What size wire Dist to HEI Module? https://slantsix.org/forum/viewtopic.php?t=59833 |
| Author: | scraigallen [ Wed Jun 29, 2016 3:21 pm ] |
| Post subject: | What size wire Dist to HEI Module? |
When I work on the HEI Module Wiring this weekend, I plan to work on the wire from the module to the distributor. What is the recommended size of wire for this? It looks like 14 or 16 gauge wire. I was thinking 12 gauge would be a little better but I am not sure. Also, I cut off the factory flat wire connector end (like an idiot) because I didn't have a matching end. Well I found that matching end, but it is still cut off. So I was thinking about using two separate male/female connectors for each wire to make it easier if I ever have to pull the motor. Any suggestions for the best way to do this? Thanks, Craig |
| Author: | Pierre [ Wed Jun 29, 2016 6:58 pm ] |
14 or 16 is way excessive for distributor to module. This is a very low current path. 18 is more then enough. Truth be told even 18 is overkill but once you get that thin you start sacrificing mechanical strength. Any male/female connectors will work really. If you want to restore the original connector you can buy a 2 pin trailer wiring harness at any autoparts store like this. Cut it in half - one end you solder back onto the distributor. Other end can mate with distributor and leads to module |
| Author: | scraigallen [ Thu Jun 30, 2016 5:23 am ] |
Thanks for the input Pierre. I may just restore that connection like you suggest. It is good to know that the smaller wire will work fine. Thanks, Craig |
