| Nitrous plate https://slantsix.org/forum/viewtopic.php?t=59835 |
| Author: | 225kid [ Wed Jun 29, 2016 8:18 pm ] |
| Post subject: | Nitrous plate |
Hey everyone, im looking to put a plate system together and i have the offy intake and i was wondering if i needed to cut the 4 holes out to work with the plate, i also have a 4 hole carb spacer on it, any help is appreciated thanks. |
| Author: | slantzilla [ Thu Jul 07, 2016 3:11 pm ] |
I ran mine with the 4 holes in the carb adapter and with them cut out. There did not seem to be much difference. How big of a shot you wanting to try? |
| Author: | 225kid [ Thu Jul 07, 2016 5:05 pm ] |
125 for sure but i was thinking about 150 |
| Author: | slantzilla [ Thu Jul 07, 2016 6:06 pm ] |
I made gobs of passes on a 150 shot. Bad things happened when I tried 175. Start at 50 until you get used to it. Stuff happen quickly when you spray. |
| Author: | Charrlie_S [ Fri Jul 08, 2016 3:40 am ] |
Quote: I made gobs of passes on a 150 shot. Bad things happened when I tried 175.
I had the same problem. But eventually I did get to about a 225 shot, on a 170 with a fogger system. PS: It didn't make too many passes at 225, before it ate a stock piston. 66 Cuda at 3250 lbs, with a stock 170 short block (just a cam). 12.905 at 101.85 mph |
