It is currently Tue May 26, 2026 11:25 am
 Post subject: HEI Diagram
PostPosted: Thu Jul 21, 2016 4:46 pm
All,
When I first did my HEI Mod, I made a few mistakes and fryed a HEI Module. I am redoing it this weekend and wanted to make sure I got it right this time. I did a schematic diagram with the wiring blocks that I plan to use.
Please look this diagram over and make sure I got it all right.
Thanks, Craig
PostPosted: Fri Jul 22, 2016 2:09 am
Looks good. Remember the switched power input could be had from the ballast resistor. Tap splice it. You could probably add this as well? Like done on this one...here. I have a few problems with this one. The 87 power from the relay is going into the ground on the coil. Both the - and + from ECU are going into the + on the coil. This is from thread 15779. Scraigallen, I like your diagram. It's easy and clean.
exoJjL
Users browsing this forum: Ahrefs [Bot], Bing [Bot], Google [Bot] and 1 guest
