It is currently Wed May 13, 2026 10:25 am
PostPosted: Thu Aug 04, 2016 7:32 am
I have 2 slant six engines out of a 1967 Clark Cortez motorhome. I am trying to identify exactly what they are. I have Chrysler serial numbers for one but the other I just have a block stamping. The block number is
8 225T 5312 ELC. Any help would be greatly appreciated.
PostPosted: Thu Aug 04, 2016 9:21 am
Welcome to the board here. H'mmm...there's a lot of variability in engine stampings, but those numbers don't make a lot of sense. The "8" should mean a 1978-model engine, and 5312 looks like a date code based on Chrysler's 10,000-day calendar, but 5312 decodes to 12 February 1976, a date too early by at least a year and a half to go along with that initial 8 (could it be a 6? They sometimes look very similar on the stamps). Or could the date code be 5812 (26 June 1977)? Always keep in mind the possibility of an erroneous stamping, too.
T: Truck engine or Trenton engine plant
E: Cast crankshaft
LC: Low compression. Er-ruh...that's weird, too. Low-compression engines, equipped with different pistons than standard-compression engines, were primarily for export vehicles sent to countries with low-octane gasoline. I guess it's possible they were also available for industrial applications where ability to run on low-test gasoline was more important than maximum torque and power.
If you are planning on taking these engines apart, it will be interesting to see what pistons are in there.
Users browsing this forum: Bing [Bot], Google [Bot] and 13 guests
