| Early Slant Engine Mounts? https://slantsix.org/forum/viewtopic.php?t=59982 |
| Author: | doc540 [ Wed Aug 03, 2016 9:17 pm ] |
| Post subject: | Early Slant Engine Mounts? |
good grief - '61 Lancer part #2203039 is sure hard to find And when one IS found - they're wanting a king's ransom for them. Any alternatives or cross overs? I'm stuck.
| Author: | SlantSixDan [ Wed Aug 03, 2016 11:23 pm ] |
No alternatives, no aftermarket coverage, and yeah, it's going to cost more than a '62-up mount, though you shouldn't have to pay the triple-digit prices I've seen around. See here for full info. |
| Author: | doc540 [ Fri Aug 05, 2016 7:16 am ] |
Thanks.... I guess my '61 could have an unoriginal engine. So, ID'ing the block could be a first step. Where would I look for the stamped engine number? It doesn't appear to be down near the alternator below the edge of the head/valve cover. |
| Author: | SlantSixDan [ Fri Aug 05, 2016 9:57 am ] |
Well, then start with the block casting number, on the side of the block under the manifolds. |
