| Identifing my industrial slant six https://slantsix.org/forum/viewtopic.php?t=59983 |
| Author: | Itsabuteclark [ Thu Aug 04, 2016 7:32 am ] |
| Post subject: | Identifing my industrial slant six |
I have 2 slant six engines out of a 1967 Clark Cortez motorhome. I am trying to identify exactly what they are. I have Chrysler serial numbers for one but the other I just have a block stamping. The block number is 8 225T 5312 ELC. Any help would be greatly appreciated. |
| Author: | SlantSixDan [ Thu Aug 04, 2016 9:21 am ] |
Welcome to the board here. H'mmm...there's a lot of variability in engine stampings, but those numbers don't make a lot of sense. The "8" should mean a 1978-model engine, and 5312 looks like a date code based on Chrysler's 10,000-day calendar, but 5312 decodes to 12 February 1976, a date too early by at least a year and a half to go along with that initial 8 (could it be a 6? They sometimes look very similar on the stamps). Or could the date code be 5812 (26 June 1977)? Always keep in mind the possibility of an erroneous stamping, too. T: Truck engine or Trenton engine plant E: Cast crankshaft LC: Low compression. Er-ruh...that's weird, too. Low-compression engines, equipped with different pistons than standard-compression engines, were primarily for export vehicles sent to countries with low-octane gasoline. I guess it's possible they were also available for industrial applications where ability to run on low-test gasoline was more important than maximum torque and power. If you are planning on taking these engines apart, it will be interesting to see what pistons are in there. |
