It is currently Sat Aug 15, 2026 9:02 pm
 Post subject: Idle problem
PostPosted: Tue Aug 09, 2016 7:58 am
Seeking advice on an idle problem...I have a 66, 225ci engine. I got the car tuned up, ran great. I then had to let it sit from like November to June of the next year. I got it up and running and now it will not idle well. It kind of lunges, as if it is stuttering to race. I have given it fresh gas, some Seafoam, run it around town, new fuel filter....still doing it. Any help would be appreciated.
PostPosted: Thu Aug 11, 2016 10:07 am
November to June is enough time for todays gas to work is magic blocking idle passages with deposits.
Easy stuff first:
Count number of turns of idle mixture screw to bottom, than remove the screw and blast / flush with carb cleaner and replace needle to same number of turns out recorded above.
If flushing did no good, freshen up carb with internal cleaning and a rebuild.
The other cause for poor idle is a vacuum leak. Check all vacuum hoses, and any diaphragm operated vacuum devices such as vacuum advance, power brake booster if equipped, and all gaskets between carb and head.
PostPosted: Thu Aug 11, 2016 1:04 pm
Thanks so much. I'll add these to my list.
Users browsing this forum: Amazon [Bot], Bing [Bot], Google [Bot] and 7 guests
