It is currently Sun Nov 15, 2026 11:51 am
PostPosted: Sun Sep 18, 2016 1:18 pm
Does anyone know if the return spring bracket on a super six car is the same as a 1 bbl car?
Found a guy who has some super six parts but doesnt have that bracket, hje said my 1 bbl bracket should work.....
Also, were super six cars offered in "lean burn"? The air cleaner he is offering has big square hold in the side that I can only assume are for lean burn stuff...our car is not a lean burn, and not going that route.
PostPosted: Sun Sep 18, 2016 4:46 pm
No, it is not. The entire linkage and spring and bracket setup is totally different for 1bbl vs. 2bl.
He's wrong, but it won't be hard to improvise a suitable bracket if you can't turn up a genuine one.
I am pretty sure the answer is yes, and so is this guy. Just fabricate a patch for the hole, run a bead of RTV silicone and then attach it with four or six short sheetmetal screws.
Users browsing this forum: Amazon [Bot], Google [Bot] and 8 guests
