| '85 D100 Slant 6 https://slantsix.org/forum/viewtopic.php?t=60142 |
| Author: | BamaFan95 [ Fri Sep 09, 2016 7:28 pm ] |
| Post subject: | '85 D100 Slant 6 |
Hello, everyone. New member here. I'm not familiar with older trucks and was hoping for some advice from the enthusiasts. My Grandad handed down his 1985 D100 to me with 60,000 miles that has been sitting up for a while now. Runs smooth and shifts beautifully. Has the 225 Slant and 727 TorqueFlite transmission. I'm doing some maintenance to bring it back up to par like changing plugs which are original (No, I am not joking), wires, distributor cap and rotor, trans fluid, antifreeze flush, etc. My Grandad used to run Castrol 20W50 oil and I changed it with Rotella T 10W30. Seemed a bit heavy of a weight to me. So my question is: What brand plugs are you guys running in your Slant 6's and which have worked the best for you, which brands to stay away from, etc? My second question is: What trans fluid is recommended for the Torqueflite? And is there a filter in the trans that needs to be replaced as well? Any help is appreciated. Thanks! |
| Author: | ceej [ Fri Sep 09, 2016 10:52 pm ] |
Welcome! I'll leave it to the experts on what is best for your truck.. They can help you determine what is best for your application. CJ |
| Author: | Wesola78 [ Sat Sep 10, 2016 6:58 am ] |
Welcome! It sounds like your truck is in great shape. I use NGK spark plugs, part number 6630. Yes, there is a trans filter. For the trans fluid, Dexron III is what I have in my '78. I'm pretty sure an '85 will use the same stuff. Others will reply and confirm this, or not. Again, welcome! |
| Author: | emsvitil [ Sat Sep 10, 2016 8:16 pm ] |
Never trust a pre-gapped plug.......... Stock is .035 I prefer .045 |
| Author: | Wesola78 [ Sat Sep 10, 2016 10:48 pm ] |
I agree with Ed. |
| Author: | BamaFan95 [ Sun Sep 11, 2016 7:31 am ] |
Sounds good. Thanks, everyone! |
| Author: | coconuteater64 [ Mon Sep 12, 2016 11:08 am ] |
If you go with the HEI conversion you should run a bigger gap. I've run 0.45 in mine for the past several years after the HEI swap. Like mentioned above, NGK is the way to go. I also run Rotella oil because it has the zinc levels that were in motor oils when these beasts were new. Never run a Fram filter. After 32 years I still have 50 pounds of oil pressure so I am sure the Rotella hasn't hurt it. My trans is a manual so can't help you there. |
| Author: | BamaFan95 [ Tue Sep 13, 2016 10:55 am ] |
Thanks for the reply! Yes, I have heard about Fram being trash and I won't even run one on my riding mower. I went with Wix on the Slant 6. I'm not sure of the quality on those, but have heard people having good luck with them. |
