| 1 vs 2 barrel Intake manifold https://slantsix.org/forum/viewtopic.php?t=60149 |
| Author: | Paulywally [ Sun Sep 11, 2016 9:06 am ] |
| Post subject: | 1 vs 2 barrel Intake manifold |
What are the advantages of getting a 2 barrel Intake manifold for a Weber 38 vs getting an adapter plate? |
| Author: | Reed [ Sun Sep 11, 2016 10:31 am ] |
(1) two barrel intake will flow better through the opening for the carb (2) hood clearance (may or may not be an issue depending on your application) You can also modify a one barrel intake to be a two barrel intake. |
| Author: | Wesola78 [ Sun Sep 11, 2016 7:15 pm ] |
I agree with Reed. The 1bbl intake will probably work okay, but the 2bbl intake will be less restrictive. And, as Reed mentioned, hood clearance could be an issue. |
