It is currently Sat Nov 21, 2026 11:13 pm
 Post subject: Changing motor mounts
PostPosted: Mon Jun 16, 2003 9:24 pm
I've got myself a floor jack, replacement mounts... only one problem: with the engine being on the slant, where do you set the jack up to do this?
'68 Valiant-100 2dr post
PostPosted: Mon Jun 16, 2003 9:30 pm
Under the pan. The trans mount should keep it from falling over. Or, you can unbolt one side at a time. :shock:
PostPosted: Tue Jun 17, 2003 12:31 pm
I just got through changing the mounts on my '66 Valiant...I just chained and lifted the engine. Worked great! The oil pan change-out was the tough part.... :roll:
PostPosted: Tue Jun 17, 2003 1:36 pm
Put a piece of 2X4 between the pan and jack head. Otherwise the pan will end up like a friends 360 crate engine and have four circular dents. :shock:
Users browsing this forum: Bing [Bot], Google [Bot] and 12 guests
