Super six return spring bracket same as 1 bbl bracket?
https://slantsix.org/forum/viewtopic.php?t=60184
Author:  shadango [ Sun Sep 18, 2016 1:18 pm ]
Post subject:  Super six return spring bracket same as 1 bbl bracket?
Does anyone know if the return spring bracket on a super six car is the same as a 1 bbl car?
Found a guy who has some super six parts but doesnt have that bracket, hje said my 1 bbl bracket should work.....
Also, were super six cars offered in "lean burn"? The air cleaner he is offering has big square hold in the side that I can only assume are for lean burn stuff...our car is not a lean burn, and not going that route.
Author:  SlantSixDan [ Sun Sep 18, 2016 4:46 pm ]
Post subject:  Re: Super six return spring bracket same as 1 bbl bracket?
No, it is not. The entire linkage and spring and bracket setup is totally different for 1bbl vs. 2bl.
He's wrong, but it won't be hard to improvise a suitable bracket if you can't turn up a genuine one.
I am pretty sure the answer is yes, and so is this guy. Just fabricate a patch for the hole, run a bead of RTV silicone and then attach it with four or six short sheetmetal screws.
