| What is this plug? https://slantsix.org/forum/viewtopic.php?t=60215 |
| Author: | shadango [ Sat Sep 24, 2016 11:51 am ] |
| Post subject: | What is this plug? |
Is the pipe plug on the right rear side of the block a water port or oil port? |
| Author: | Reed [ Sat Sep 24, 2016 12:01 pm ] |
Block cleanout port to drain and clean out the water jacket around the cylinders. |
| Author: | shadango [ Sun Sep 25, 2016 8:22 am ] |
Ah.....ok. So not a good place to insert a temp gauge probe I guess? |
| Author: | Doctor Dodge [ Sun Sep 25, 2016 9:23 am ] |
Temperature sending units are best placed in the cylinder head or near the outlet / coolant exit point so you can get a reading from the hottest running zones in the engine. Based on that... the thermostat cover is a good location for an aftermarket temp gauge. DD
| Author: | shadango [ Sun Sep 25, 2016 11:01 am ] |
Quote: Temperature sending units are best placed in the cylinder head or near the outlet / coolant exit point so you can get a reading from the hottest running zones in the engine.
Do they sell thermostat housings with that already drilled out or is this a home brew sort of deal?Based on that... the thermostat cover is a good location for an aftermarket temp gauge. DD ![]() Is there enough room in the housing for the thermostat if the sensor is mounted in it like that?? I just looked at my housing and how the thermostat sits in it and it looks like there wouldnt be room. I guess I can always go this route https://www.summitracing.com/parts/atm-2281/overview/ |
