| Alternative to the "remflex" heat riser gasket?? https://slantsix.org/forum/viewtopic.php?t=60225 |
Page 1 of 2 |
| Author: | shadango [ Mon Sep 26, 2016 11:40 am ] |
| Post subject: | Alternative to the "remflex" heat riser gasket?? |
I was reading that the remflex heat riser gasket is better than the metal gasket for between the intake and exhaust manifolds..... But HOLY COW....... It's $20 for that little gasket PLUS another $14 to ship it UPS ground! That's $35...seem exorbitant for a gasket..... Any lesser costly alternatives? Don't really want to have to do this job twice, but holy cow......it's a GASKET. |
| Author: | Reed [ Mon Sep 26, 2016 11:48 am ] |
You get what you pay for. You can try the metal shim gasket between the manifolds, but you most likely won't get a good seal. Remflex costs more for a reason- it WORKS. Having tried Remflex gaskets on several slant sixes, now I will only use Remflex for the manflds and exhaust gaskets. I used the Felpro and Victor Reinz gaskets for years and the Remflex gasket is far superior. |
| Author: | 67Charger [ Mon Sep 26, 2016 11:58 am ] |
I'm pretty sure you can get them through Summit and Amazon and save on the shipping big time. I tried them and will NEVER use anything else again. |
| Author: | SlantSixDan [ Mon Sep 26, 2016 12:50 pm ] |
| Post subject: | Re: Alternative to the "remflex" heat riser gasket |
Quote: I was reading that the remflex heat riser gasket is better than the metal gasket for between the intake and exhaust manifolds.....
Yes—like, the Remflex one will seal, and the stamped metal one won't.Quote: But HOLY COW.......It's $20 for that little gasket PLUS another $14 to ship it UPS ground!
Buy the whole set at a more favourable price.Quote: Don't really want to have to do this job twice
Is why the options are to use the Remflex gasket or wish you had...!
| Author: | Rick Covalt [ Mon Sep 26, 2016 6:03 pm ] |
How about $5. I probably have one out in the garage, but I'll have to check tomorrow for sure. How about this; you try and come to a slant 6 race sometime and I will give you the gasket for shipping. How's that? |
| Author: | Danarchy [ Mon Sep 26, 2016 7:11 pm ] |
$38 for both Intake/exhaust and heat riser is what I paid (+$4 shipping) and with the results, I would have no problem paying double that price! You Get What You Pay For! |
| Author: | shadango [ Tue Sep 27, 2016 5:18 am ] |
Since the topic of the intake/exhaust gasket was brought up -- what about what I have seen referenced as the "aussie gasket" ? I am also wondering about a gasket I have heard of made of Thermoseal/Klingersil --- folks seem to say it is reusable. |
| Author: | Danarchy [ Tue Sep 27, 2016 6:51 am ] |
shadango you are over-thinking this. Buy the Remflex, Install and be done with it! |
| Author: | shadango [ Tue Sep 27, 2016 7:22 am ] |
Quote: shadango you are over-thinking this. Buy the Remflex, Install and be done with it!
LOl, maybe overthinking to some.....BUt I am on a budget on this build.....and a reusable gasket would be great hence my asking. I use reusable header gaskets ("Percy", I think) on my 72 barracuda's headers and love them. |
| Author: | shadango [ Tue Sep 27, 2016 8:32 am ] |
Quote: How about $5. I probably have one out in the garage, but I'll have to check tomorrow for sure. How about this; you try and come to a slant 6 race sometime and I will give you the gasket for shipping. How's that?
I sent you a pm. |
| Author: | Danarchy [ Tue Sep 27, 2016 9:23 am ] |
How often do you plan to pull the intake/exhaust? |
| Author: | Rick Covalt [ Tue Sep 27, 2016 12:14 pm ] |
Quote: Thermoseal/Klingersil --- folks seem to say it is reusable
Yes it is very good and can be used over multitple times. The Remflex is much softer and that may be good in many if not most applications. But if you plan on removing the Intake/exhaust several times the stiffer green gasket may be a good choice. I have reused the one on my valiant at least 4 times.Brian Droschak from your back yard just had them re-done And they were less than the Remflex. |
| Author: | shadango [ Tue Sep 27, 2016 1:38 pm ] |
Quote: How often do you plan to pull the intake/exhaust?
Well hopefully NEVER again....LOL.But we all know how that goes. If I can save $40 for a gasket in the event of a second "take" on the install, it would probably help since there would be a bigger (maybe costly) reason to go thru all that again. But if there is a reason to not use something like the Thermoseal, then I would obviously consider that. So I dont consider it OVERTHINKING so much as CAREFUL thinking. I like options and exploring the best ones for me. |
| Author: | Reed [ Tue Sep 27, 2016 2:41 pm ] |
Remflex is your best option. The metal shim with copper RTV sealant on each side is a poor second choice. |
| Author: | shadango [ Tue Sep 27, 2016 4:24 pm ] |
Quote: Remflex is your best option. The metal shim with copper RTV sealant on each side is a poor second choice.
Where would the thermoseal gasket fall then?
| Page 1 of 2 | All times are UTC-08:00 |
