| Changing motor mounts https://slantsix.org/forum/viewtopic.php?t=6023 |
| Author: | R_Pinson [ Mon Jun 16, 2003 9:24 pm ] |
| Post subject: | Changing motor mounts |
I've got myself a floor jack, replacement mounts... only one problem: with the engine being on the slant, where do you set the jack up to do this? '68 Valiant-100 2dr post |
| Author: | slantzilla [ Mon Jun 16, 2003 9:30 pm ] |
Under the pan. The trans mount should keep it from falling over. Or, you can unbolt one side at a time. |
| Author: | 6 gun [ Tue Jun 17, 2003 12:31 pm ] |
I just got through changing the mounts on my '66 Valiant...I just chained and lifted the engine. Worked great! The oil pan change-out was the tough part.... |
| Author: | Eric W [ Tue Jun 17, 2003 1:36 pm ] |
Put a piece of 2X4 between the pan and jack head. Otherwise the pan will end up like a friends 360 crate engine and have four circular dents. |
