It is currently Thu Aug 06, 2026 8:53 am
 Post subject: 4 speed automatic swap
PostPosted: Fri Sep 30, 2016 10:29 am
I am looking for the ecm/pcm pinout for a 95 ram van, the info below may help with your conversion. Check on the engine forum for more swap info I have found on magnum swap.
http://www.dippy.org/forum2/index.php?topic=231.0
https://transmissioncenter.net/shop/727 ... nformation
Advise should be taken as ongoing, that way, when you get to realizing what you are doing you can include yourself.
