It is currently Sun Nov 15, 2026 7:55 pm
PostPosted: Mon Oct 10, 2016 11:42 am
I'm going to be installing an oregon cam GRIND #346. Lift is .476 int .479 exh. Will stock springs be able to deal with that amount of valve lift? Any recommendations are appreciated.
 Post subject: Yep...but...
PostPosted: Mon Oct 10, 2016 4:08 pm
Yes they would be able to take it, but for how long is the question. It would be a better recommendation to get a set of the 318/340/360 springs with the smaller damper springs for better seat pressure and knowing they will last a bit longer if you decide to go for higher rpms/aggressive driving....
PostPosted: Mon Oct 10, 2016 4:12 pm
Thanks a ton!
PostPosted: Mon Oct 10, 2016 4:13 pm
They would work at that lift, but you probably couldn't turn over 5000 rpm without them falling on their face.
PostPosted: Tue Oct 11, 2016 10:59 am
... Lift is .476 int .479 exh.
Be sure to check the clearance between the top of the valve guide & the spring retainer, at full lift.
( also allow room for the valve stem seal you plan to run)
The tops of the SL6 head's valve guides usually need some trimming. when running lifts over .460.
