| Rough Idle and stalling after new carb. https://slantsix.org/forum/viewtopic.php?t=60331 |
| Author: | my1983d15037521 [ Tue Oct 18, 2016 8:43 pm ] |
| Post subject: | Rough Idle and stalling after new carb. |
| Author: | SlantSixDan [ Wed Oct 19, 2016 7:43 am ] |
"Remanufactured" carburetors and distributors (and starters, and alternators, and...) tend to be junk. Exactly what carb did you buy, and from where? "No air/fuel adjustments" is wrong right off the bat; all carbs have air/fuel adjustments -- if yours doesn't, something's wrong. Cancel that order for the "rebuilt" distributor. Don't just buy and toss on parts at random. |
| Author: | my1983d15037521 [ Wed Oct 19, 2016 1:58 pm ] |
Holley 1 Barrel 1945 |
| Author: | my1983d15037521 [ Wed Oct 19, 2016 2:03 pm ] |
Rockauto- AUTOLINE C7386 Holley 1 Barrel 1945 Rockauto- A-1 CARDONE 303691 Dual Pickup; without Vacuum |
| Author: | SlantSixDan [ Wed Oct 19, 2016 2:28 pm ] |
Yup, "remanufactured" junk. Since we're talking about a dual-pickup distributor, it means you've got the Lean Burn system, which is notorious for breaking down over the years (remember how old this truck is) and causing poor running. You've got some decisions to make; your best way forward is probably to ditch the Lean Burn and put in HEI with an appropriate carburetor. |
