| WTF did I do wrong?!? https://slantsix.org/forum/viewtopic.php?t=60342 |
| Author: | oldnslo [ Fri Oct 21, 2016 5:02 pm ] |
| Post subject: | WTF did I do wrong?!? |
I am attempting to do a KH 4 piston swap and change the bushings. I installed the UCA's on what I thought was the correct sides, but the ball joint wasn't even close to the spindle. If I swap the UCA's to what I presume is the wrong sides, the ball joint can reach the spindle, but it's at a CRAZY angle. Where did I go wrong? |
| Author: | Rick Covalt [ Fri Oct 21, 2016 6:21 pm ] |
got a picture ? |
| Author: | '67 Dart 270 [ Fri Oct 21, 2016 6:35 pm ] |
| Post subject: | bumper |
the rubber bumper and stop on the UCA should tell you if you have them on the correct side, i.e. the rubber bumper should be registered with a stop on the UCA. brian |
| Author: | Joshie225 [ Fri Oct 21, 2016 7:53 pm ] |
You must unload the torsion bar and lift the lower control arm. |
| Author: | oldnslo [ Sat Oct 22, 2016 9:16 am ] |
I will post pics as soon as I can, weather cooperation needed. The torsion bars are out, so no load there |
| Author: | ski [ Sat Oct 22, 2016 10:07 am ] |
Does it matter what side the spindles are on? |
| Author: | oldnslo [ Sat Oct 22, 2016 10:36 am ] |
They can only go on one side |
