| Wrong choke pulloff? https://slantsix.org/forum/viewtopic.php?t=60345 |
| Author: | shadango [ Sat Oct 22, 2016 7:45 am ] |
| Post subject: | Wrong choke pulloff? |
So when I bought a BBD from a fellow member here, he graciously included a new choke pulloff.....I assumed it would fit and merrily went along my way and forgot about it till now... Looks like this may be for a different application? The rod makes it to the choke bracket on the carb fine but the clip wont work.....unless I am missing something here.....it looks like the rod would need to come from a different direction for the clip to clear properly..... I was thinking of going to the electric choke kit talked about elsewhere but was planning on waiting a bit to see how this one worked.....
| Author: | SlantSixDan [ Sat Oct 22, 2016 8:38 am ] |
That's not a choke pull-off you're talking about, it's a choke thermostat. The clip is supposed to straddle the choke lever and then swing onto the pushrod -- can't tell from your photo if the clip is right-handed or wrong-handed; they're available both ways. The № 1232 Electric choke kit is a much better idea than this. |
| Author: | DusterIdiot [ Sat Oct 22, 2016 9:00 am ] |
| Post subject: | Yep... |
Quote: can't tell from your photo if the clip is right-handed or wrong-handed; they're available both ways.
You can always make notes on what works and get a new clip that faces the correct direction from the orange Dorman drawers at the appropriate autoparts store...
| Author: | SlantSixDan [ Sat Oct 22, 2016 1:14 pm ] |
That's 'cause your clip is wrong-handed. You need its mirror image, and it straddles the top of the choke lever. Do as DusterIdiot suggests. |
| Author: | shadango [ Sun Oct 23, 2016 7:39 am ] |
Quote: That's 'cause your clip is wrong-handed. You need its mirror image, and it straddles the top of the choke lever. Do as DusterIdiot suggests.
Yeah I am gonna take the clip and my pic to pep boys and see what they might have......I havent seen "dorman drawers" anywhere.....but carded parts by them so I am crossing my fingers....Was hoping someone might have a picture to help me find the right piece here. The intention is to use this for now and get the electric choke setup later...project creep is already killing me here.....LOL |
| Author: | matv91 [ Sun Oct 23, 2016 9:06 am ] |
http://www.ebay.com/itm/162140986736?_t ... EBIDX%3AIT look close at picture. I bought that clip from this seller,it worked on 77 78 but not on 79 . I think you have this one already. |
| Author: | SlantSixDan [ Sun Oct 23, 2016 9:24 am ] |
Quote: Yeah I am gonna take the clip and my pic to pep boys and see what they might have
Almost certainly nothing; you need to go to an actual, real parts store. The dingus you need is either this or this.
| Author: | matv91 [ Sun Oct 23, 2016 9:44 am ] |
http://slantsix.org/forum/viewtopic.php ... sc&start=0 Read that ,you may have the wrong choke thing on carb. carter 14-1045 Ill send one if needed |
| Author: | shadango [ Sun Oct 23, 2016 11:14 am ] |
Quote: Quote: Yeah I am gonna take the clip and my pic to pep boys and see what they might have
Almost certainly nothing; you need to go to an actual, real parts store. The dingus you need is either this or this.It would appear I have the "right " one (your second this, though it doesnt have the second loop on it. My local store has the left one in stock, I guess I iwll try it......cant get the geometry right in my head as far as how that would make a difference but I am sure its just my "piss offed ness" right now,......frustration.....LOL Gonna head off to the store for that and see if I can figure out an adaptor to gain me 1.5" on my trans line easily. NOTHING can EVER be easy. LOL |
| Author: | matv91 [ Sun Oct 23, 2016 11:36 am ] |
Made copy of your picture,took it out to car. Looks like carter 14-1079 for the 79 cars which needs the other clip. |
| Author: | shadango [ Sun Oct 23, 2016 7:14 pm ] |
OK, so I got the ";eft" one at the store and lo and behold it works....now I get the geometry.... Thanks all, for the help! Dan, you were spot on! This place rocks! |
| Author: | SlantSixDan [ Mon Oct 24, 2016 9:34 am ] |
Glad to help out. Those clips are like the helical distributor drive pinion: stare at it for too long and you'll burn out your brain. |
