| Slant six throttle cable https://slantsix.org/forum/viewtopic.php?t=60377 |
| Author: | Magnumforce1987 [ Wed Oct 26, 2016 7:45 pm ] |
| Post subject: | Slant six throttle cable |
Hey dudes and dudets, got a 68 barracuda slant 69 with a clifford intake and holley 2 barrel set up. What seems to be the problem is that the throttle cable I have now is of a small block. It's too short (from Oakland) and wondering for this conversion, if I need a slant 6 throttle cable or a new lokar throttle cable. |
| Author: | Matt Cramer [ Thu Oct 27, 2016 7:51 am ] |
I would recommend just going to a bicycle store and using a mountain brake throttle cable. You can get them in any length. |
| Author: | JNL [ Sat Oct 29, 2016 4:39 am ] |
| Post subject: | Re: Slant six throttle cable |
Quote: I would recommend just going to a bicycle store and using a mountain brake throttle cable. You can get them in any length. Quit your mocking.Quote: Hey dudes and dudets, got a 68 barracuda slant 69 with a clifford intake and holley 2 barrel set up. What seems to be the problem is that the throttle cable I have now is of a small block. It's too short (from Oakland) and wondering for this conversion, if I need a slant 6 throttle cable or a new lokar throttle cable. Whoa. Is that a super 6 conversion for the Holley 2BBL? Is that a Holley 2280 by chance? You need to be more specific here Magnum. If this is the case, the original throttle cable for the one barrels carbs (at least on 72' +) is that they're (if I recall 22" long.) The throttle cables for the super six are the same ones used for the 318ci V8 which are 19.5" long. Hope this helps.
| Author: | sandy in BC [ Sat Oct 29, 2016 6:11 am ] |
Quote: Quit your mocking.
Now there's an insult based on ignorance......Matt is right...and you lack credibility. |
| Author: | DusterIdiot [ Sat Oct 29, 2016 10:25 am ] |
| Post subject: | Option #2... |
Depending on the throttle plate orientation (especially if it is bore parallel to the head/engine), you can get a Spectre throttle bracket in the aftermarket aisle of your autoparts store , then use a long throttle cable from a late 80-90 Dodge mini-van, or from an 80's Aries/Reliant if you are hunting in junkyards.... (This is what I do on my hyperpak intakes, and worked even on a super six manifold mounting a Holley 2305 carb...) FYI. |
| Author: | JNL [ Sun Oct 30, 2016 6:55 am ] |
Quote: Quote: Quit your mocking.
tNow there's an insult based on ignorance...... Matt is right...and you lack credibility. |
| Author: | sandy in BC [ Sun Oct 30, 2016 7:47 am ] |
| Post subject: | Slantsix throttle cable. |
All right. Matt is correct. You can get a throttle ( or any similar cable) made up at a bike shop in any length with any ends. Its inexpensive and available. ....and , yes we all read the thread title...Matt gave the information...which I backed up. |
