| 66 Valiant, the Hot Rod In Training https://slantsix.org/forum/viewtopic.php?t=60466 |
Page 1 of 2 |
| Author: | halfafish [ Sat Nov 19, 2016 9:05 pm ] |
| Post subject: | 66 Valiant, the Hot Rod In Training |
| Author: | emsvitil [ Sat Nov 19, 2016 9:50 pm ] |
Max width tire on 4.5" wide rim is 185 75 You'll need 5.5" wide for 205 70 Also 7/8 rear anti sway bar is a bit much with slant up front...... (I have 3/4 on mine) Use photobucket or equivalent for photos. And HI! |
| Author: | Joshie225 [ Sat Nov 19, 2016 10:55 pm ] |
I look forward to seeing the finished product! I approve of everything except the rear sway bar as you can get neutral handling without it and a lot of oversteer with it. |
| Author: | ceej [ Tue Nov 22, 2016 7:03 am ] |
| Post subject: | Re: 66 Valiant, the Hot Rod In Training |
Quote: I'm not having any success posting the photos. Some help perhaps from someone who knows the secret handshake?
The forum doesn't host photos. Host them someplace like photo bucket, then link them here.Welcome to dot org! CJ |
| Author: | halfafish [ Thu Nov 24, 2016 10:03 am ] |
I think I figured out how to use photobucket, yay for this caveman! Let's see if it works. Here are the photos of the car when I drove it home. Other than the knucklehead that sawed out the dash for the DIN radio, it's an unmolested survivor. http://s86.photobucket.com/user/junk471 ... sort=3&o=5 Here is the next update, as I installed rear speakers, took out and replaced the gawdawful botched-up front speakers, fixed all the wiring, and installed a new stereo. Also, the new radiator set-up, and an upgrade to 14" tires and wheels (originally yellow, then repainted to match the car). http://s86.photobucket.com/user/junk471 ... t=9&page=1 |
| Author: | halfafish [ Wed Dec 21, 2016 7:01 am ] |
Time for an update. So far I've driven the car for a few months, mostly to give it a shake-out and see what needs work. I fixed leaks at the rear end, gearbox, and oil pan. The radiator had a split seam, so it was replaced with an aluminum Champion unit as noted in the link below. http://www.forabodiesonly.com/mopar/thr ... ap.359779/ The radio was a mess with an old, incorrect, shaft unit that was just stuck in place in the dash. One of the PO's had cut out the dash to take a modern DIN radio and I didn't want to monkey with fixing it so I put a modern unit in place. The dash speaker was old, rotten, and inoperative so I made a mounting plate and stuck a pair of 4" speakers up front. The rear package shelf got a new set of 6x9's. A note if you're going to replace your rear speakers and your package shelf is original as mine was. Don't crank down the speakers too hard when mounting them. I did, and they pulled down and damaged the shelf material. Luckily, the speaker grills cover the damage but I ruined the original shelf by not knowing any better. I'm going to Kelsey Hayes front discs, so changed the tires and wheels to 14" SBP steelies to fit over the calipers. The fronts are 4.5" with 205/70's on them, and the rears are 7" with 245/60's mounted. The rear wheels were made by the guy I got them from, and were assembled from Mopar SBP centers welded to some Ford 7" rims. They came out pretty well and are all the tire/wheel I can get under the rear fenders without moving springs, tubbing, or shaving wheel wells. Here's a shot of the radiator, in place and working very well. Since I put it in, the gauge hasn't moved once the thermostat opens. It's probably a bit of overkill but I didn't want to mess with upgrading again later when the engine gets built up. ![]() The radio set-up. This is a Bluetooth radio, so I stuck the mic inside the ashtray so it's out of sight unless I want to use it. ![]() ![]() ![]() And the new tires/wheels. Originally they were yellow, I painted them to match the car. ![]() ![]() Next up is a complete front-end rebuild (PST), a brake upgrade with dual-chamber master cylinder and KH discs, new T-bars (PST), new front sway bar (Hellwig), new rear springs (Firm Feel), new shocks all around (Bilsteins), and a new 20:1 steering box (Firm Feel). Here's the heap-o-parts waiting for installation, starting next week. ![]() Next update in a few weeks when it comes down off the jack stands! |
| Author: | Dart270 [ Mon Feb 20, 2017 5:20 am ] |
Looks like nice progress on the shop, and the parts accumulation and planning. Lou |
| Author: | Louise76 [ Mon Feb 20, 2017 11:25 am ] |
Me thinks Halfafish is solidly hooked. |
| Author: | ceej [ Mon Jun 19, 2017 8:04 pm ] |
Looks good! I'll have to try your method as my current paradigm isn't working. I clean out my shop by giving stuff to Travis and Mike, they clean out their shops by giving me their stuff. We all still have great junk all over the place. CJ |
| Author: | halfafish [ Mon Jun 19, 2017 10:24 pm ] |
Aha. I'm familiar with this - it's an affliction called Crapitis, and I have it in spades. I hold yard sales and give stuff to Goodwill, then go to yard sales and Goodwill with an eye toward some screaming bargain. It doesn't make much sense. However, I took a vow that everything I had to remove from the shop for the installers to have room to work (which was just about everything) has to earn it's way back inside. Plus, if I haven't touched it in a year and I'm not likely to do so in the next six months, out it goes. |
| Author: | ceej [ Tue Jun 20, 2017 12:18 am ] |
Gahghh! Six months! Waow! you are strict! OK. Barnaby, come get the intake. I'll mount the trade in on the Hooptie! CJ |
| Author: | DusterIdiot [ Tue Jun 20, 2017 8:29 pm ] |
| Post subject: | Lol... |
Zach's seen my shop... he needs a few more projects in his, but he's got a nice shop... I'll get there with mine soon enough.... |
| Page 1 of 2 | All times are UTC-07:00 |
