| Overheating Slant https://slantsix.org/forum/viewtopic.php?t=60470 |
| Author: | crickhollow [ Mon Nov 21, 2016 1:02 am ] |
| Post subject: | Overheating Slant |
Reasons for overheating? Radiator looks ok, I have reversed flushed and there was a little muck. Thermo looks ok too, the correct temperature rating (I think) 180F. Hoses seem ok. Water pump works ok. Engine block - not sure. It has been flushed and some much came out, but not much. Ideas and advice appreciated. Thanks. |
| Author: | DusterIdiot [ Mon Nov 21, 2016 5:40 am ] |
| Post subject: | Is it... |
Quote: Thermo looks ok too, the correct temperature rating (I think) 180F.
Does it open is the better question, pull the stat and dump it into a boiling pot of water... let sit a for a bit and see if it opens, if not time for a new one... Had that happen on a Stant stat after 14 months of daily driving, it just would barely open and stick killling the water flow...
