| Bolt size for engine stand https://slantsix.org/forum/viewtopic.php?t=60473 |
| Author: | Wesola78 [ Mon Nov 21, 2016 11:09 am ] |
| Post subject: | Bolt size for engine stand |
For a slant six to be mounted on an engine stand. Anyone know the size? |
| Author: | Pompis [ Mon Nov 21, 2016 12:25 pm ] |
3/8 UNC |
| Author: | MOUSETRAP [ Mon Nov 21, 2016 12:51 pm ] |
| Post subject: | Eng stand |
Use caution as motor is extreamly unbalanced I ended up with the 2 legged stand with support rods down to stand legs I would recommend a few buddies there when you want to rotate the motor |
| Author: | '67 Dart 270 [ Mon Nov 21, 2016 1:01 pm ] |
| Post subject: | bolts |
I use grade 8 bolts and those even get bent some. I use a Harbor Freight engine stand, it seems plenty strong enough. I did use a longer pipe handle to make rotating the engine easier for one person, my handle is about 3 feet long (the one that comes with it is only maybe 18" long or so,way too short for much leverage). Brian |
| Author: | DusterIdiot [ Mon Nov 21, 2016 5:53 pm ] |
| Post subject: | Yep... |
Size will be dependent on what holes in the block you use... I typically set the prong up to use 2 of the upper bolt holes into the block, and the outboard arms through the lower holes/ears on the tombstone, which would require a longer bolt with nuts and washers at both ends...you can adjust the center of the prong to have a better center and balance for the engine... at least until the head and manifold are on it... You should use a washer at the head of the bolts and they will take the load of the engine better, I have yet to bend a grade bolt... I have 3 harbor freight engine stands that I bought back in the 90's and they originally held mid-70's 400 big blocks....make sure to use a 4 wheel stand not the 3 wheel... |
