| Slant 6 powerwagon https://slantsix.org/forum/viewtopic.php?t=60475 |
Page 1 of 2 |
| Author: | Magnumforce1987 [ Mon Nov 21, 2016 2:30 pm ] |
| Post subject: | Slant 6 powerwagon |
Hey guys, got a 1975 dodge w100 clubcab short bed. My 360 and tranny took a dump in the same time, I got access to a slant 6 with truck 727 and divorced transfer case. Is it worth doing a slant 6 powerwagon? My truck has 4" lift, with dana 44, 33" tires, and 3.54 gears. |
| Author: | Reed [ Mon Nov 21, 2016 2:53 pm ] |
Ooof. I love the slant, but that is a beast of a vehicle to move around with just a 225 and 3.5 gears. THe slant will do it, but don't expect to go fast or climb steep hills. |
| Author: | Magnumforce1987 [ Mon Nov 21, 2016 3:14 pm ] |
Not planning on going over 70-75 and with mild hill climbing |
| Author: | Reed [ Mon Nov 21, 2016 3:22 pm ] |
If you had a long enough straightaway you could get up to 75. |
| Author: | Magnumforce1987 [ Mon Nov 21, 2016 3:46 pm ] |
So, you wouldn't recommend. |
| Author: | Brian [ Mon Nov 21, 2016 4:51 pm ] |
Go for it |
| Author: | DusterIdiot [ Mon Nov 21, 2016 5:42 pm ] |
| Post subject: | Lol... |
I actually schucked a NP435 clutch setup for a guy putting together a hill side hunting RamCharger 4x4 with a supersix, 9:1 scr and comp 252 cam... they were running 28" tires and 4.11's and said it crawled along in 4x4 just fine.... Your combination will run... but with the 33" tires and the 3.54's it may lug out at a start and may take a few football fields to get up to speed.... With the heavy vehicle the 4x4 and the bigger tires... you will need to swap out the rear gears for something more like 4.11's or 4.56's to be kind to the slant to get things motivating....especially uphill.... |
| Author: | Reed [ Mon Nov 21, 2016 8:49 pm ] |
| Post subject: | Re: Lol... |
Quote: I actually schucked a NP435 clutch setup for a guy putting together a hill side hunting RamCharger 4x4 with a supersix, 9:1 scr and comp 252 cam... they were running 28" tires and 4.11's and said it crawled along in 4x4 just fine....
This the point I was trying to make but expressed much better.
| Author: | Magnumforce1987 [ Mon Nov 21, 2016 9:16 pm ] |
That being said, I am aware that I need truck slant six motor mounts, can I use the engine cross member I have now (for V 8)and cross member (from 727 married case)? |
| Author: | Reed [ Mon Nov 21, 2016 11:00 pm ] |
Quote: That being said, I am aware that I need truck slant six motor mounts, can I use the engine cross member I have now (for V8) and cross member (from 727 married case)?
Yes. The trucks and vans use the same engine crossmember (K frame) for both six and eight clinder motors, but different motor mounts. The transmission mount should also be the same.
| Author: | afastcuda1970 [ Tue Nov 22, 2016 11:14 am ] |
I have an '84 W100 regular cab long bed with a slant and NP 435 manual. It has 33" tires an 3.55 gears. It is pretty weak at highway speeds but not bad around town. I would bump up the compression put in a bigger cam and at least a two bbl carb. Don't expect 360 performance though. |
| Author: | Magnumforce1987 [ Tue Nov 22, 2016 12:25 pm ] |
Quote: I have an '84 W100 regular cab long bed with a slant and NP 435 manual. It has 33" tires an 3.55 gears. It is pretty weak at highway speeds but not bad around town. I would bump up the compression put in a bigger cam and at least a two bbl carb. Don't expect 360 performance though.
I really like the idea of a turbo slant 6 for my powerwagon.
| Author: | afastcuda1970 [ Wed Nov 23, 2016 10:28 am ] |
Quote: Quote: I have an '84 W100 regular cab long bed with a slant and NP 435 manual. It has 33" tires an 3.55 gears. It is pretty weak at highway speeds but not bad around town. I would bump up the compression put in a bigger cam and at least a two bbl carb. Don't expect 360 performance though.
I really like the idea of a turbo slant 6 for my powerwagon. |
| Author: | Magnumforce1987 [ Wed Nov 23, 2016 10:30 am ] |
Are the engine mounts hard to get ahold of? The slant six I have access to has no engine mounts. |
| Author: | Reed [ Wed Nov 23, 2016 11:30 am ] |
Any 1972-1987 slant powered truck or van will have them. Be sure to get the truck/van oil pan and oil pickup tube as well. |
| Page 1 of 2 | All times are UTC-07:00 |
