| Clutch free travel? https://slantsix.org/forum/viewtopic.php?t=60488 |
Page 1 of 2 |
| Author: | Rick Covalt [ Thu Nov 24, 2016 12:01 pm ] |
| Post subject: | Clutch free travel? |
Have a question on a 85 4X4 with Slant 6/ granny gear transmission, 11" clutch. We pulled the engine to rebuild and get a little more get up and go. Clutch and PP looked good so we decided to leave it in. Just cleaned it all up and reinstalled it. Last evening we set the engine back in and today I noticed that there is no free travel. Yes I checked adjustment. And it appears to me that the throw out bearing is clear back against the nose of the transmission and the throw bearing is just touching the pressure plate fingers. This has a diaphragm clutch in it so I am assuming that it has been changed at some time. So now what to do? This truck has been off the road for 2 years but I think it worked Ok, since Ryan dumped the clutch on it and split the rear end yoke with it!! I know the newer cars don't have free travel, but I am pretty sure this needs some. But I am hoping that I am wrong. Thanks for the advice. Rick Happy Thanksgiving to everyone. |
| Author: | jeepsterhemi [ Thu Nov 24, 2016 4:37 pm ] |
| Post subject: | Re: Clutch free travel? |
Quote: I know the newer cars don't have free travel.......
I remember an answer by E-Berg, from Mopar Action, where he says that ''newer'' bearing doesn't need free travel....unlike the '60 and '70 ones!!! It's all about bearing quality....if I remember well!!!!
| Author: | Rick Covalt [ Thu Nov 24, 2016 6:43 pm ] |
Well that sure would be nice if that was the case. Does anyone else have experience with these clutches? DI maybe? Thanks! Rick |
| Author: | afastcuda1970 [ Thu Nov 24, 2016 7:23 pm ] |
I don't believe the '85's had the 11" clutch as an option. If you have one, someone may have done a swap. I'm not sure on the free play but I will check my '84 tomorrow but it has a 10" clutch. |
| Author: | DusterIdiot [ Thu Nov 24, 2016 7:41 pm ] |
| Post subject: | Hmmmm.... |
Not sure since the only 11" truck clutch I have is in my car... that being said the diaphragm clutch in my car, the TOB is riding on the diaphragm fingers and there is about 2 fingers between the back of the TOB and the face of the bearing retainer....(but I also have a 5/8" spacer between the back fo the bellhousing and the face of the transmission...)... This bell housing has the older square hole style of arm retainer and not the late ballstud version.... |
| Author: | emsvitil [ Thu Nov 24, 2016 9:57 pm ] |
Self adjusting hydraulic clutches don't have freeplay. Non seld adjusting hydraulic clutches and cable clutches do have free play. The freeplay is taken up with clutch wear............. |
| Author: | Rick Covalt [ Fri Nov 25, 2016 5:14 am ] |
Quote: the TOB is riding on the diaphragm fingers
That is where this one is. So it may be OK that way? I figure that would where out the TOB much sooner. Maybe I'm worrying about nuttin!I'd say this looks to be the factory set up with the 11" clutch but I could be wrong. Rick |
| Author: | DusterIdiot [ Fri Nov 25, 2016 9:03 am ] |
| Post subject: | Lol... |
Quote: I figure that would where out the TOB much sooner. Maybe I'm worrying about nuttin!
Even with the spec clutches in my rig, once you remove the overcenter spring to use a diaphragm clutch the TOB will ride on the fingers all the tims and not come off it, it shouldn't be a problem, but like you I do worry and check the TOB every so often just of peace of mind... |
| Author: | Rick Covalt [ Fri Nov 25, 2016 11:24 am ] |
Ok DI, that is good news. I did get the premium TOB so I think I will just continue the assembly process. Thanks, Rick |
| Author: | afastcuda1970 [ Fri Nov 25, 2016 7:31 pm ] |
My truck has about 1" of free play at the pedal. |
| Author: | DusterIdiot [ Fri Nov 25, 2016 9:55 pm ] |
| Post subject: | Yep... |
Quote: My truck has about 1" of free play at the pedal.
That's the factory free play allowance for all mopars with a mechanical linkage clutch.
| Author: | Rick Covalt [ Sat Nov 26, 2016 5:07 am ] |
Quote: I don't believe the '85's had the 11" clutch as an option.
They were available through at least 86 according to the FSM I have.I would guess they were available until the last run of the Slant 6. |
| Author: | afastcuda1970 [ Sat Nov 26, 2016 12:16 pm ] |
Quote: Quote: I don't believe the '85's had the 11" clutch as an option.
| Author: | DusterIdiot [ Sat Nov 26, 2016 12:22 pm ] |
| Post subject: | Then... |
Quote: I wish mine had an 11" clutch. I don't trust that 10" clutch.
Do you have a picture of your 1984 setup with the NP435?Given the differences between the mating flange on the other manual transmissions, I'd like to see how your set up mates to the smaller bellhousing and clutch... |
| Author: | afastcuda1970 [ Sat Nov 26, 2016 1:22 pm ] |
| Post subject: | Re: Then... |
Quote: Do you have a picture of your 1984 setup with the NP435? Given the differences between the mating flange on the other manual transmissions, I'd like to see how your set up mates to the smaller bellhousing and clutch... The engine to bell looks them same as my a833 od in my FD. It has the high mount starter and the bellhousing bolts are on the outside. I haven't looked at the bell to trans but it would have to mount like all other NP435's. |
| Page 1 of 2 | All times are UTC-07:00 |
