It is currently Mon Oct 26, 2026 4:16 am
 Post subject: 62 lancer floor shift
PostPosted: Tue Dec 27, 2016 10:59 am
my 62 slant lancer has 3 on the tree. would like to convert to floor shift.
what I need if: I keep the slant 3 speed? as far as hump and shifter? OR.....
IF if I go with slant 4 speed OD unit???????
want something that works well, not worried bout it being some sort of correct show poodle!? ha thanks
anyone wit needed parts???
my email is billbarbee222@yahoo.com and ph is 417-350-5951 evenings before 8 p.m. central time please
 Post subject: You will need....
PostPosted: Tue Dec 27, 2016 4:03 pm
If going floor shift on both you will need a hump, proper carpet, transmission and matching bellhousing (if going A-833OD especially), shifter, rods, shift lever, floor bezel and boot...
If retaining your older 3 speed, you need to inspect the tailshaft... Mopar occasionally cheaped out and had a version well into the early 70's that was only for column shift and had no mounting bosses for a floor shifter... some people have adapted a shifter to one, and others have mounted the shifter to the floor pan (just be aware that if the motor and transmission mounts are compromised or you take a good pothole you might shift out of gear with that set up... or worse in an accident).
If you use a late bellhousing (either for a switch to an A-230 synchro 3 speed, or the A-833/833OD) you may also need to fabricate an adaptive mount to make sure the Z-bar will align right with the bellhousing and body mount).
Good Luck.
PostPosted: Wed Dec 28, 2016 6:14 am
thanks for the info. I have changed over B and later A bodies from auto to 4 speeds, and as always with mopar, nothing is ever that simple! ha....
