It is currently Sun May 03, 2026 7:04 pm
 Post subject: Tranny > radiator lines
PostPosted: Tue Jun 17, 2003 7:30 pm
Due to the way the lines are bent, and the way my exhaust pipes were bent for the clifford headers, I can't bolt the bracket to the bottom of the bellhousing to keep the lines out of the way. Right now the lines are sitting awfully close to the exhaust pipe. Has anyone replumbed these lines? What did you use? Any ideas?
 Post subject: Tranmission Lines
PostPosted: Wed Jun 18, 2003 7:21 am
SSRN National Champion
I replaced my lines on a 73 duster with clifford headers. We used hydraulic hose lines that are flexible so i could get them away from the heat.
PostPosted: Thu Jun 19, 2003 1:35 am
Norm, what kind of fittings did you need and where did you get everything? What was total cost?
