Gasoline in the oil?
https://slantsix.org/forum/viewtopic.php?t=6060
Page 1 of 1
Author:  Jopapa [ Fri Jun 20, 2003 7:36 pm ]
Post subject:  Gasoline in the oil?
So it seems the Dart is getting gasoline into its oil somehow, though it's not burning any oil (which would point to bad piston rings I would figure). What else could cause that?
Author:  Reed [ Fri Jun 20, 2003 7:49 pm ]
Blown diaphragm in the fuel pump. If you have a leaky fuel pump diaphragm the gas can drain directly into the crankcase via the fuel pump shaft (hole in the block for the fuel pump arm to ride on the cam lobe).
Replace the fuel pump and see if the problem goes away.
Reed
Author:  Jopapa [ Fri Jun 20, 2003 7:55 pm ]
Cool, I'll see if that helps.
Now, uhhh, I'm having a senior moment; what's ECS?
Author:  Reed [ Fri Jun 20, 2003 9:42 pm ]
Environmental Contamination Services?
What is it in reference to?
Reed :?:
Author:  Jopapa [ Fri Jun 20, 2003 11:50 pm ]
I just saw the exact same stuff on a "california spec" pump, so I remembered it's Emission Control System, which this car doesn't have :lol:
Author:  Michael_Cuda [ Mon Jun 23, 2003 3:15 am ]
I have a interesting story about this. Told to me by my father. Happen to a 65 Fury w/ 318. He gets a call from my mother that the car died, so he walked down to there it was.... and he was noticing a trail on the ground... it it fallowed right up under the car... lol
The fuel pump was dumping gas into the crankcase... and filled up so much it was running out.... this caused problems the engine had to be rebuilt soon after this...
Author:  Slanted73 [ Mon Jun 23, 2003 8:21 am ]
Post subject:  gas in all the wrong places...
I was doing a rebuild on a 318 after finding an extra 3 quarts in the oil pan. Hmm smelled of gas. Burned like gas in a coffee can. The engine practically sparkled inside, but the bearings didn't appreciate it. After two failed mechanical fuel pumps I went to an electrical pump.
