| 62 lancer floor shift https://slantsix.org/forum/viewtopic.php?t=60601 |
| Author: | barbee6043 [ Tue Dec 27, 2016 10:59 am ] |
| Post subject: | 62 lancer floor shift |
my 62 slant lancer has 3 on the tree. would like to convert to floor shift. what I need if: I keep the slant 3 speed? as far as hump and shifter? OR..... IF if I go with slant 4 speed OD unit??????? want something that works well, not worried bout it being some sort of correct show poodle!? ha thanks anyone wit needed parts??? |
| Author: | DusterIdiot [ Tue Dec 27, 2016 4:03 pm ] |
| Post subject: | You will need.... |
Quote: what I need if: I keep the slant 3 speed? as far as hump and shifter? OR.....
If going floor shift on both you will need a hump, proper carpet, transmission and matching bellhousing (if going A-833OD especially), shifter, rods, shift lever, floor bezel and boot...IF if I go with slant 4 speed OD unit??????? If retaining your older 3 speed, you need to inspect the tailshaft... Mopar occasionally cheaped out and had a version well into the early 70's that was only for column shift and had no mounting bosses for a floor shifter... some people have adapted a shifter to one, and others have mounted the shifter to the floor pan (just be aware that if the motor and transmission mounts are compromised or you take a good pothole you might shift out of gear with that set up... or worse in an accident). If you use a late bellhousing (either for a switch to an A-230 synchro 3 speed, or the A-833/833OD) you may also need to fabricate an adaptive mount to make sure the Z-bar will align right with the bellhousing and body mount). Good Luck. |
| Author: | barbee6043 [ Wed Dec 28, 2016 6:14 am ] |
thanks for the info. I have changed over B and later A bodies from auto to 4 speeds, and as always with mopar, nothing is ever that simple! ha.... |
