Slant Six Carter BBD 2bbl Linkage
https://slantsix.org/forum/viewtopic.php?t=60609
Author:  Shahab Hanif Khan [ Fri Dec 30, 2016 1:10 am ]
Post subject:  Slant Six Carter BBD 2bbl Linkage
Dear All,
Thanks for allowing me to get register in the Forum. I have visited the forum since I bought my Plymouth Duster 1975 SL6 225 CID with TF 904. unfortunately I lost the user name and password so, Thanks to Mr. Chuck to allow me again. Last time all of you specially Mr. Dan and Mr. Reed was so helpful to repair my TF 904.
This time I would like to get help for the BBD 2 BBL linkage. I have converted my single barrel (Pic-1) intake to two barrel ( Pic-2) and install brand new Carter BBD 2 BBL (Pic-3). As per the instruction found some where in the Forum. now the carb is Horizontal to the engine so the linkage is facing towards the fire wall (90 Deg to the actual position) .
can some one send me the pictures for accelerator wire and throttler linkage smellier to mine. so, i can do the same for my car? Thanks
Picture-1
Picture-2
Picture-3
Author:  Shahab Hanif Khan [ Fri Dec 30, 2016 3:17 am ]
Here are some Pictures of Carter BBD 2 BBL
Author:  SlantSixDan [ Fri Dec 30, 2016 11:18 am ]
I don't have the pictures you need, but I am glad to have helped and I hope you will have a happy new year.
Author:  Reed [ Fri Dec 30, 2016 11:31 am ]
Unfortunately, there is no diagram to help you. Your carburetor system was not a factory option and no factory linkage system exists for it. You will have to create your own. I recommend you use a cable style kickdown linkage. Your factory throttle cable may work if it is long enough. If it is not, you will have to use an aftermarket throttle cable system.
Good luck!
Author:  SlantSixDan [ Fri Dec 30, 2016 1:31 pm ]
On second thought, you might want to take a look at the parallel 2bbl setup article. Photo documentation of a very well done such conversion is here, though that was for an older car with a different kind of linkage.
Author:  Shahab Hanif Khan [ Fri Dec 30, 2016 8:50 pm ]
Thanks Mr. Dan the second link having good information but involving very complicated lever system. but it give me a very good idea what should I do for my Duster.
Thanks and have a very Happy new year.
Author:  Shahab Hanif Khan [ Fri Jan 06, 2017 1:53 am ]
Hi Guys ,
would like to know is this air cleaner fix on carter BBD 2 bbl carb? if yes any idea how to do that?
Author:  Shahab Hanif Khan [ Mon Jan 09, 2017 10:51 pm ]
any Idea guys ? can i fix the above pictured air cleaner to my Duster 2 bll carter carb ??
Author:  Shahab Hanif Khan [ Mon Jan 09, 2017 10:53 pm ]
