| Super Six Carter BBD Accelerator Return Springs https://slantsix.org/forum/viewtopic.php?t=60616 |
| Author: | jkotis [ Mon Jan 02, 2017 12:03 pm ] |
| Post subject: | Super Six Carter BBD Accelerator Return Springs |
Does anyone know where I can get the correct accelerator return spring and automatic transmission kickdown lever return spring for a Super Six setup using a Carter BBD carburetor and automatic transmission? I haven't been able to find the part numbers either. I don't have to have NOS parts but would buy them if available. |
| Author: | gdizzle [ Tue Jan 17, 2017 8:16 am ] |
You are hunting for some of the rarest parts around. Good luck. For the throttle return spring bracket, I ended up using a straight wrench for a Router tool. you know that tool that comes with your power tools to tighten the collet. |
| Author: | matv91 [ Wed Jan 18, 2017 5:18 pm ] |
http://slantsix.org/forum/viewtopic.php ... ht=#431781 |
