Ignition Conversion ?????
https://slantsix.org/forum/viewtopic.php?t=6062
Author:  speedfreak [ Sat Jun 21, 2003 11:20 am ]
Post subject:  Ignition Conversion ?????
i have an 83 dodge pickup with a 225 super six, i swapped out the lean burn system for the older type, i got the truck to run but it runs real rough and pops through the carb and is real hard to start. I've lined up the rotor with the number 1 terminal on the distributor... i haven't looked in my chiltons book yet, that 's the next step. just wanted to know what some of your input is on swapping out the lean burn system...any help would greatly be appreciated.
speedfreak... :?
Author:  87Slant_sickness [ Sat Jun 21, 2003 12:25 pm ]
Are you sure you have the firing order right? sounds to me like the timing could be out...
Justin
Author:  Reed [ Sat Jun 21, 2003 8:13 pm ]
Your distributor may be 180 degrees off. #6 and #1 are at TDC at the same time, but one is at TDC n the compression stroke and one is at TDC at the end of the exhaust stroke. If have seen a slant six run with the distributor 180 degrees off so it is not imposible. Try swapping plug wires around before you pull the dist. If it fixes it, pull the dist, move the rotor 180 degrees and put the plug wires back in correctly.
Reed
Author:  Doctor Dodge [ Sat Jun 21, 2003 10:36 pm ]
Do you have a timing light?
If it runs, it is easy to check the timing with a timing light.
Adjust as needed, you may need to loosen the plate hold down screw on the bottom of the distributor or move a tooth to get the timing correct.
Author:  zorg [ Sat Jun 21, 2003 11:19 pm ]
If you don't have a timing light, you can still adjust the timing by ear. As Doc said, losen the plate hold down screw (at the bottom of the dist.) and rotate the dist. Clockwise advances, counterclockwise retards. If it starts to ping, back off a little bit and you're good to go.
Author:  speedfreak [ Tue Jun 24, 2003 7:02 am ]
fist off thanks guys #1 wire on the cap was wright,it was the other 5 that were wrong, LOL, well its running,and off to the next poject,,, 8) speedfreak.
