| Air Cleaner ? https://slantsix.org/forum/viewtopic.php?t=60644 |
| Author: | Shahab Hanif Khan [ Mon Jan 09, 2017 11:00 pm ] |
| Post subject: | Air Cleaner ? |
Hi Guys , would like to know is this air cleaner fix on carter BBD 2 bbl carb? if yes any idea how to do that? which car air cleaner it is? ![]() ![]() ![]() ![]() ![]() ![]()
| Author: | 65 dartman [ Tue Jan 10, 2017 8:25 am ] |
It looks like a 4 barrel air cleaner, so it would not fit a 2 barrel. I have no idea of what it came from |
| Author: | Reed [ Tue Jan 10, 2017 9:07 am ] |
Can you show us the part of the air cleaner that attaches to the carburetor? I am not seeing how that air cleaner will attach to a carburetor, and it is the size of the opening for the carburetor that matters. If it is an air cleaner for a four barrel carburetor, you can buy adapters to put a four barrel air cleaner on a two barrel carburetor, provided you have enough clearance under the hood. |
| Author: | coconuteater64 [ Tue Jan 10, 2017 9:30 am ] |
Hood clearance is the real issue. That's a HUGE air cleaner housing! |
