It is currently Fri Nov 20, 2026 1:33 pm
PostPosted: Mon Jan 02, 2017 12:03 pm
Does anyone know where I can get the correct accelerator return spring and automatic transmission kickdown lever return spring for a Super Six setup using a Carter BBD carburetor and automatic transmission? I haven't been able to find the part numbers either. I don't have to have NOS parts but would buy them if available.
PostPosted: Tue Jan 17, 2017 8:16 am
You are hunting for some of the rarest parts around. Good luck. For the throttle return spring bracket, I ended up using a straight wrench for a Router tool. you know that tool that comes with your power tools to tighten the collet.
66 dodge dart 270, 225ci, 3.7l, L6
PostPosted: Wed Jan 18, 2017 5:18 pm
http://slantsix.org/forum/viewtopic.php ... ht=#431781
