| Custom Kickdown Adjustment https://slantsix.org/forum/viewtopic.php?t=60727 |
| Author: | SlantSixDan [ Sat Feb 04, 2017 10:14 am ] |
You're gonna have to do some geometric tweaking so the throttle throw and the kickdown throw are coordinated, otherwise it'll never shift right for you. That may mean a shorter lever at the transmission end (to "compress"/shorten the kickdown lever throw) or it may mean moving the manifold-end attachment point of the kickdown further away from the throttle shaft axis to lengthen the throw of the kickdown cable, or it may mean ditching the cobbled-up links and seeing this thread for kickdown options. I'd sure like to know more about your custom EFI setup! Maybe in a different thread. |
| Author: | Reed [ Sat Feb 04, 2017 11:06 am ] |
I would ditch all parts of the factory kickdown and just go straight to a cable style kickdown. |
